Hello Dankninja,
Based on the processor specifications, the T-junction of the Intel Core i9 12900k processor is 100°C. Any temperature results below or equal to that value are considered normal and expected for this unit.
About this scenario, it is important to mention that, when using third-party tools, the results shown in those applications might not be that accurate.
To make sure if actually, the cores are working properly, even though the processor is not listed as supported, install and run the Intel Extreme Tuning Utility. You might be able to strictly monitor the temperature and the clock speed in real-time and confirm if there is something wrong with the unit.
It is also important to mention that when you benchmark the component, it will be submitted into artificial stress that will make the CPU run at its Maximum. This type of stress test does not reflect the same impact as a game will present, and the workload will be higher on the stress test, that's why you may see differences in the temperatures between gaming and benchmarking.
Jean O.
Hello Dankninja,
I hope you are doing fine.
Jean O.
Hello Dankninja,
Thanks for your response.
Once you try checking the XTU, let me know if you face any issues.
Jean O.
Hello Dankninja,
Jean O.
Hello Dankninja,
I am glad to know the information helped, and everything looks to be working fine. Hopefully, it will help other community members. Since the thread is now solved, I will close it. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Jean O.
