Processors
14503 Discussions
Hope to help confirm X5 Z8350 USB2.0 and camera circuit design
zorro
The usb2.0 interface and rear camera function test of the Z8350 motherboard we designed is not normal. Now we have changed the design and also referred to the PDG and RVP design.
But we still can’t confirm that our usb2.0 circuit and rear camera circuit are OK, now I would like to ask experts to confirm it for us, and we have not yet
The driver of rear camera ov8858 on WINDOWS10 system, thank you!
AndrewG_Intel
Hello @zorro
Please allow us to check further regarding these inquiries. As soon as we have more details available we will be posting back in this thread.
Andrew G.
AndrewG_Intel
Hello @zorro
Thank you for your patience in this matter.
After checking this further, we noticed that this seems to be related to custom hardware design and integration with Intel® components.
In this case, we would like to recommend addressing this inquiry to our Resource & Design Center where you may find technical documentation, software, tools, and support you need to design and build with Intel® products.
Some of this information it's public and some other information might need special rights, for instance, a Corporate Non-Disclosure Agreement (CNDA) with Intel.
 You need to register first and create an account in order to access the public resources available. Please refer to the Sign-in link.
In addition, your Hardware Design inquiry might also require a closer look by an Intel Field Application Engineer (FAE).
If your company has its own Intel representative, you may want to inquire if they can assist you with this inquiry. If you do not have a contact, you may want to speak with a Field Application Engineer from a local distributor to see whether they are able to help.
A list of Intel® Authorized Distributors can be found here: Intel® Authorized Distributors and Approved Suppliers
Having said that, we will proceed to close this inquiry now. Thank you for your understanding.
Andrew G.
