Processors
15863 Discussions
How can I get the IO Margin Tool for i5-8400
Elon_z
I want to download the IOMT tool for i5-8400. But I can't search the tool location.
Earl_Intel
Hi Elon_z,
To better assists you and determine the most appropriate resolution, could you please provide the needed details listed below:
  • May I know where will you use it for?
  • What is the make and model of your motherboard?
  • What BIOS version do you currently have on your system?
  • Can you describe the issue more to us?
Kindly run this on your system so that I can also gauge the following peripherals and the driver versions that you have:
Intel® System Support Utility for Windows*
Once finished downloading, open the tool, click on scan (leave the default items checked), click next, then save the system information to a .txt file. Please provide us the .txt file.
Earl E.
Elon_z
Hi Earl E,
Thank you for your reply.
I want to use IOMT to measure SATA port signal for SSD.But I don't have this tool.I have collected the system information with the tool you provided.
BRs,
Elon_z
Earl_Intel
Hi Elon_z,
Earl E.
