I have a HP Omen i7-9750H and I want to UV the cpu using intel XTU, but this message appears when I finish the installation.
XTU only supports X and K processors. You have an H processor.
Doc
Some friends have the i7-8750H and they can install it and use it. I have researched about this message and some users have the same issue.
Ps: I installed a previous version and it worked, but i would like to use the latest.
Nonetheless, if you read the XTU download page, you will see that is says XTU is only valid for X and K processors.
Doc
