My current CPU model is Intel Xeon Platinum 8180M 2.50 GHz . Now I want to know how can calculate or find terfaflops (tflops) for this system ? I am not using any VGA device on my system
Hello Alexxz1,
Thank you so much for your response.
In this case, the model that you have is considered an OEM-only model; therefore, you will have to go directly with the vendor to whom the processor was purchased and get any the technical information or documentation directly through them, once you have reached them out you can ask them to get the information for you by requesting a Field engineer to be assigned to your request, you can also open a ticket in our IPS support channel and request the information there.
Victor G.
Intel Technical Support Technician
