Sorry to make another dumb question about memory size.
Xeon Platinum 9282 comes with max 2TB memory size, max 12 channels, 2 dimms per channel, which means max 24 dimms per socket. Hence I did a simple calculations, (2TB / 24) = 85.3 (GB/dimm). AFAIK, one ddr4 dimm can have 64GB maximum.
How is it possible? Does this have to do with supporting 3DXP based memory module of Cascade Lake? Or is there any other way to achieve max 2TB size by normal ddr4 dimms?
Thank you for your help in advance.
- Tags:
- Intel® Xeon®
Hello HyeongTak
Thank you for joining the community.
We are looking the correct documentation for better answer your question. In the meantime can you tell where did you see the max RAM size of 2TB? Looking at both the ark.intel.com and the official Xeon Platinum websites I was not able to see the max RAM size though.
Jose A.
Under Contract to Intel Corporation
Hello HyeongTak,
I am just following up to double check if you were able to gather the requested information. Otherwise let us know if you require more time to accomplish this.
If you consider the issue to be completed please let us know so we can proceed to mark this thread as resolved.
This thread will be marked as resolved automatically in the next 72 hours if no activity is received.
Jose A.
Hello HyeongTak,
We will proceed to mark this thread as resolved. If you have further issues or questions just go ahead and create a new topic.
Jose A.
