Processors
14539 Discussions
How to disable L2/L3 cache in Intel® Core(TM) i7-4790 ?
Rekha
I am trying to find the memory bandwidth in my system.
My code does the following
1. get the start time
2. start the counters to measure cache-misses( using papi_counters)
3. do memory writes
4. stop the counter and read its value
5. get the end time; calculate the overall time needed for the memory access
Before executing this code I flush the cache so I can get all the memory writes as misses
Repeat the above steps for memory access of 32, 64, 128,256,512,1024 bytes
The time needed for doing memory access is 1035, 1050,1121,1078,1065,1112 useconds
I find the results to be weird, if the time taken for 32 access is X, then for 64 access shouldn't it be 2*X and soon on. Just had a thought of disabling L2 and L3 can help me find an answer to this issue. I did not any source on how to disable the L2/L3 cache.
Any suggestions would be really appreciated.
It would be great if someone could help me, to figure out why is this misbehavior happening.
Thanks in advance
Rekha K R
Alberto_Sykes
Rekha, Thank you for posting in the Intel® Communities Support.
In reference to your inquiry, for us to be able to provide the most accurate assistance on this matter, we just wanted to confirm:
Is there any particular reason why you need this information?
Are you a software developer?
Are you working on a project?
If that is the case, what is that project about?
Albert R.
A Contingent Worker at Intel
Rekha
I am doing my Master thesis based on CPU and memory management. I want to find the maximum bandwidth of my memory.
NO.
No, This work is a part of my Master thesis.
I need to find the maximum memory bandwidth, If there is a way to find without disabling my higher-level cache would also work for me.
Rekha K R
Alberto_Sykes
Rekha, Thank you very much for providing those details.
In order to gather the information you are looking for, please visit, sign-in and submit your inquiry in the Intel® Software Forums Support, where you will receive further peer to peer technical assistance on this topic:
https://community.intel.com/t5/Software-Products/ct-p/software-products
Albert R.
