josbo6, Thank you for posting in the Intel® Communities Support.
In order to provide the most accurate assistance for this case we just wanted to confirm a few details about your system:
What is the model of the Intel® Processor?
What is the model of the motherboard?
If this is a laptop, what us the model of it?
Which Windows* version are you using?
When you said "Brand String fail" are you referring to the Intel® Processor Diagnostics Tool test?
Is your Intel® Processor failing only that part of the test or the end results of the test is "Failed"?
In the following link you will find the manual of the Intel® Processor Diagnostics Tool, in there on page 20 you will see what the "Brand String test" does:
Alberto R.
A Contingent Worker at Intel
Hello josbo6, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Alberto R.
Hello josbo6, Since I have not heard back from you, we are closing the case, but if you have any additional questions, just reply back or post a new question.
Alberto R.
