Problem is when i start gaming on device it start thermal throttling at 70Ā°C š , and what i know is 6700HQ thermal throttle limit is 80Ā°C Celsius what can i do to fix this
And i use Intel XUT app to monitor all these issues
My CPU run 72-70Ā°C while gaming and it show thermal throttling and i have tried put down core voltage offset to -0.120V not much effect
The throttling implementation is a product of your laptop manufacturer. Sometimes, configuration parameters for this feature are provided in BIOS Setup. Ultimately, though, you will need to contact your laptop manufacturer regarding what you can (or can't) do with this feature.
Hope this helps,
āupdate the bios , or don't overclock , update all drivers including intel management firmware , and its componnets
