I saw on Intel Product Specifications > Processors
That i can upgrade to 16GB RAM..
and the problem is i can't even find the right specifications i want to upgrade the RAM.. Like i'm searching for (PC3-10700 1333HMz 8GB RAM or event 4GB without any luck)
And i can't find it anywhere, but there is a lot of (PC3-12800 1600MHz 8GB RAM per stick)
so can i use 12800 1600mhz instead of 10700 1333hmz ?
or even at least 1 8GB ram in a single slot ? if the answer is YES to the question above.
Thanks in advance. i just want some opinions from others.
Regards.
Dell knows all about Dell laptops. Dell is solely responsible for your support. You need to contact Dell.
Note that even though the processor may support 16gb, how dell designed and built the laptop is another matter.
Contact dell and ask them all your questions.
Doc
