Its not normal .
This highest occurs by running lots a background applications and with windows services .
Some unwanted potential problems may be running background by utilizing all resources .
Some corrupted drivers doing these
try to uninstall waste applications and unused applications.
Sfc /Scannow
Dism.exe /Online /Cleanup-Image /StartComponentCleanup
Dism.exe /Online /Cleanup-Image /RestoreHealth
Hello MRodr29
Thank you for posting in the Intel Community.
You can run the Intel® Processor Diagnostic Tool to review the processor status in case of any failure reported (https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool).
I recommend to have the BIOS up to date and to load default BIOS settings (in order to take BIOS actions we recommend contacting the system manufacturer). If the behavior still persist this behavior has to be handle with the Original Equipment Manufacturer (OEM).
Hope this helps.
Leonardo C.
Hello MRodr29
I was checking your case and would like to know if you need further help. If so, please do not hesitate in replying back.
Leonardo C.
Hello MRodr29
Leonardo C.
I'm from Brazil I have the same problem of CPU heating, the motherboard, processor and memory have been replaced by the warranty twice, and the problem has not been solved, is it a manufacturing problem for DELL or Intel?
Topic Options
