You must ask toshiba what processors THEIR bios supports. Then, you can select from those processors. And, this is only possible if your current processor is NOT soldered to the motherboard.
An upgrade processor must be socket, chipset, and BIOS compatible.
If a bios update is required, the bios will have to come from - drum roll - toshiba.
And, if a bios update is required, it MUST be done with the existing processor.
Doc
Is it socket, chipset, and BIOS compatible- is what I am asking.
You have to ask toshiba if it is bios compatible. It is their bios, not intel's.
Contact toshiba.
Doc
Also, you may want to compare the two processors here:
https://ark.intel.com/content/www/us/en/ark/compare.html?productIds=53464,53432
Doc
