In 9100f's page it says it supports ddr4 2400mhz, does it not support 2133mhz? I can't go into bios to change it to 2400mhz...
Good question for your motherboard manufacturer. The processor has no graphics, and it does support 2400.
Is your motherboard bios updated?
Doc
Yes, they updated it to the latest bios version. So if my motherboard is running at 2133mhz this cpu just won't work until I change to 2400mhz profile?( I have an external gpu installed)
No, it should still run, just with the slower memory.
I would try different memory.
Doc
What is the model number of your motheboard?
Doc
It is MSI H310M PRO-VD, my ram is working on another system at both 2133 and 2400mhz so seems like something's wrong with the cpu. I'm probably going to return this cpu and buy it from somewhere else.
So, it cannot possibly be your board or memory, right? It must be the processor, right?
Everyone wants to take the easy path, which is to blame the processor. Even if the memory works in another machine, TRY DIFFERENT MEMORY.
Returning the cpu and buying from somewhere else? You mean getting the same cpu from another source, or a different CPU?
Doc
I sent the motherboard to service and they said they updated to latest bios, tested everything and it was all functional.
I only have 1 stick of Ddr4 ram with me right now.
And I meant buying the same cpu from another source.
Please try different memory.
Doc
Also, you did have the monitor(s) connected to the add-in graphics card and not to the motherboard, right?
Yes, I connected the monitor to the gpu.
