I have a problem with the processor's performance with CPU i5-10400f
And I put it in the XTU test benchmark ,This is the result shown in the picture
A fluctuating result in performance between going up and down.
I confirmed that the problem is not with the graphics card from other tests
- Tags:
- i5-10400f
Hello mohammad_ali
Thank you for sharing your concern and running the Intel XTU benchmark to gather insights.
Kindly answer the following questions:
- What is your system's power plan?
- Have you made any recent changes to the system?
- Have you made adjustment in your BIOS Settings?
Kindly provide as well the summary/ logs of the XTU so that we may further investigate the said results.
Please generate an SSU report to help me further analyze important details on your system. To generate the SSU report, please refer to the article: How to get the Intel® System Support Utility Logs on Windows*. Please send us the generated SSU.txt file.
We look forward to your response!
Robbie R.
Hello mohammad_ali,
Robbie R.
Hello mohammad_ali,
Robbie R.
