Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file (using the paperclip under the toolbar).
Doc
Thanks for helping out, here it is!
No attachment. Please do it again.
Doc
I would first try updating your MSI BIOS.
Doc
Ill try it! thanks!
I looked at my Bios, and it already has the latest version, installed around 2 months ago.
Any other solutions?
Hello KMull7
We are checking this thread and we would like to know if you need further assistance.
If this behavior persists, we would like to check if it is linked to an Intel® process. Please refer to the following details:
1- Right-click on your Start button to open the WinX Menu. Select Run. This opens the Run box. Now type services.msc in it and hit Enter to open the Services Manager and take a screenshot of all the Services related to "Intel" and please attach them to this thread.
2- This could be related to the Telemetry software running on the background and that is what we are trying to isolate, or you could try uninstalling Intel® Driver & Support Assistant (Intel® DSA) and any references to Intel Program Improvement then restart and check if the issue persists.
Note:
To attach a file, you must click the “Attach” option on the bottom left-hand corner of the response box.
Andrew G.
Hello KMull7
Thank you for your response.
In this case, we would like to gather additional details to investigate this further, could you please provide the following information?
1- Details or screenshots listing all the Intel® Apps and Intel-related software in Windows® Settings >> Apps & Features.
2- Screenshots from Windows® Task Manager showing:
a- "Processes" tab ordered by the "CPU" column.
b- "Performance" tab showing CPU utilization.
3- We understand Intel® DSA is not installed in the system. By any chance do you know if it was installed before in the system and then removed/uninstalled from the computer?
4- Is the high CPU utilization behavior by this particular process occurring randomly or all the time without changing/decreasing?
5- Did your system work fine before? Was there any Windows, driver, software, or hardware change at the moment where you noticed this behavior?
Andrew G.
Hello KMull7
We are checking this thread and we would like to know if you need further assistance. If yes, could you please provide the information requested in our previous post?
Andrew G.
Hello KMull7
We have not heard back from you so we will proceed to close this inquiry. If you need further assistance please do not hesitate to contact us back.
Andrew G.
