The Asus website does not list it, but because the motherboard is somewhat old, I'm pretty sure the 4790k did not exist at the time, so maybe the list isn't updated. The socket matches, but I haven't found anyone who has paired these two components together.
Here's a link to the Motherboard at the Asus site: http://www.asus.com/Motherboards/P8H77M_PRO/HelpDesk_CPU/ P8H77-M PRO | Motherboards | ASUS Global
Any help would be appreciated!!
Thanks!
Andres Bordeu
Hello abordeu ,
Unfortunately the motherboard is not compatible but if you are interested in taking a look at the motherboards compatible with the Intel® Core™ i7-4790K Processor you can see it here:
http://processormatch.intel.com/MotherBoards/CompatibleBoards http://processormatch.intel.com/MotherBoards/CompatibleBoards
Best wishes,
Ivan
Not the same socket. My bad!
Not only that, the processor must be socket AND BIOS compatible. Look on the asus site for a list of compatible processors.
Doc
Yep. I guess I should be looking at the i7 3770k instead. Thanks for the reply!
Hello abordeu ,
Best wishes,
Ivan
