Processors
16110 Discussions
I'm looking for a bios for i7-3770S
Muhadib
Hello
I'm looking a bios version 0041 for update:
DH61BE
DH61CR
DH61DL
DH61WW
DH61SA
DH61ZE
It is for to install an i7 third generation and after proceed until 0120 version.
Many thanks
n_scott_pearson
I have attached a ZIP file that provides all of the BIOS files necessary. To help you with the installation, here are my notes:
A. My step-by-step instructions for BIOS Recovery:
  1. NOTE: Read these instructions completely before starting. Follow all instructions EXACTLY.
  2. On some other Windows-based PC, download the .BIO file for the BIOS release you wish to install.
  3. Insert a 32GB or smaller (the smaller the better) USB 2.0 flash drive into the PC. Do not use USB 3.0 flash drives (most are not compatible). It is also better (though not required) to use a flash drive that has an access LED that you can watch.
  4. Format this USB flash drive using the Windows Format applet. Specify to install the FAT32 file system (Important: NOT vFAT, NOT exFAT; FAT32 only). You must also specify that the Quick Format option be Disabled (unchecked).
  5. NOTE: If FAT32 is not offered as a choice by the Format applet, your flash drive is too big; use another.
  6. Copy the .BIO file into the root folder of this USB flash drive. This should be the only .BIO file in the root folder of the USB flash drive.
  7. Properly eject the USB flash drive. Do not just yank it out. Do this from File Explorer or using the Safely Remove Hardware and Eject Media System Tray applet.
  8. Power off the Desktop Board system.
  9. Remove the yellow BIOS Configuration jumper from the board. It will be the only yellow jumper; the rest will usually be black.
  10. Plug the USB flash drive into one of the black USB 2.0 ports on the back panel of the board. Avoid using blue USB 3.0 or Yellow USB 2.0/3.0 charging ports. Also avoid using front panel USB ports.
  11. Power on the system.
  12. The BIOS Recovery process should start automatically. You should see a progress report on your main monitor.
  13. NOTE: If you do not see a progress report displayed on a monitor, do not power off the system for at least 15 minutes. While it is rare, it is possible for the process to proceed without an onscreen display; you must give it ample time to complete, just in case.
  14. When the BIOS Recovery process is complete, you will be asked to power off the system. Do so then.
  15. Restore the yellow BIOS Configuration jumper to the pins it was on previously. This should be across pins 1 and 2 of this (three pin) header.
  16. Remove the USB flash drive from the back panel of the board.
  17. Power on the board.
  18. Immediately begin pressing the F2 key, over and over (approx. once per second) until you see a BIOS Setup (or Visual BIOS) screen displayed.
  19. Verify, using the BIOS version string, that the BIOS installed properly. Stop if it isn't.
  20. Press the F9 key (followed by the Y key) to reset of the BIOS configuration.
  21. Press the F10 key (followed by the Y key) to save the BIOS Configuration and exit BIOS Setup.
  22. Once screen is cleared (goes black), begin pressing the F2 key, over and over, until you see the BIOS Setup screen displayed.
  23. Make any changes to the BIOS configuration that you desire (for example, disabling NUMLOCK) or that you require (for example, setting Boot Order, enabling UEFI, etc.).
  24. Press the F10 key (followed by the Y key) to save the BIOS Configuration and exit BIOS Setup.
  25. Test.
B. Some additional thoughts on BIOS Recovery:
  • If BIOS Recovery will not start, try using a different USB port. You can try using the blue USB 3.0 or yellow USB 2.0/3.0 ports as well if no other choices. You can also try using front panel USB ports.
  • If switching USB ports didn't work, try using a different USB flash drive. Remember that all USB flash drives must be reformatted at least once using the process described in Step 4 above.
  • As always, it is helpful to use a USB flash drive that has an access LED so that you can visually see if it is being accessed.
  • If you are seeing USB flash drive being accessed but BIOS Recovery does not start, a common cause is compatibility with the memory present. The BIOS Recovery engine, as it is with USB 3.0 flash drives, can be very picky with regards to memory compatibility. Try removing all but one DIMM/SODIMM.
  • For more information on the BIOS Recovery process, consult Intel Desktop Boards Recovery BIOS Update Instructions.
C. Some thoughts on updating these boards:
  • There are pertinent instructions in the BIOS Release Notes (BE0120.pdf).
  • My additional notes on the process (once you have BIOS 41 installed):
    • Perform Steps 1 - 22, using BE0048.BIO at Step 6.
    • On USB flash drive, delete BE0048.BIO and add BE0099.BIO
    • Perform Steps 7 - 22.
    • On USB flash drive, delete BE0099.BIO and add BE0120.BIO
    • Perform Steps 6 – 26.
Hope this helps,
n_scott_pearson
  25. Test.
Hope this helps,
Muhadib
Hello Scott thank you very much for the files, I have already update to 0035 version. I tried the bios recovery procedure according to the indications but appears a warning that it is not possible to use it from 0035. Then I tried with F7 and appears the warning "bios 0035 does not permit the F7 bios update process to be used please update bios using Iflash or Intel express bios update". Now I will try with a bootable pen drive
MattVonGrimm
Hello Scott,
I'm having issues updating from 0035 to 0041, I have the BIOS updates you provided and a copy of Rufus as I'm getting the "BIOS 0035 does not permit the F7 BIOS update process to be used please update BIOS using IFlash or Intel Express BIOS Update".
I'm not sure what I need to do.
I followed your instructions in the thread.
I tried removing the jumper on the board and updating with a USB 2.0, 1 GB stick, and the BE0041P.bio file copied onto it, twice (using different rear ports), all I get is a blank screen and no activity, I left it for 30 minutes each time (to be safe), but no joy, it won't update the BIOS, I even tried diffferent USB ports on the back of the board.
I see someone said (Muhadib, in this thread) that they used Rufus to get it to work, but didn't go into detail on how.
Any advice would be much appreciated as I want to get it updated to at least 0048 so I can install an Intel Core i5-3750K.
At the moment I'm in a jam.
Thanks in advance.
Matt.
MattVonGrimm
Hello Scott,
Thanks in advance.
Matt.
OOPS! Double-Posted, sorry!
edwin_r
Dear Scott. Thanks you for helping the community, and excuse me if i'm reviving such an old topic. I have a question:
I have an DH61WW (verified, i opened the chassis, even extracted the mobo).
Upgraded to 0048, seems to be ok.
Then upgraded to 0099 using the .BIO provided in the .zip file. All went ok too. Rebooted, pressed F2,  and i see my mobo is identified as DH61BE, please see the atached photo.
Is this normal?  Do you have the 0099.BIO for the DH61WW?
i've got the CH341A programmer, performed a backup of my original dump 0045. So, i reverted to this version for safe operation, but my goal is to update to 0120
Thanks for your answer.
Ambertslot08
Hello n_scott_pearson. Thanks For The Bios Update, I've recently updated My bios From 0.0046 To 0.0099 And After Upgrading It To 0.0099 My Ethernet Is Not Working ( It's Showing Up On Device Manager ) And Also On the Ethernet Cable Port The green Light Is blinking But in Device Manager A error is appearing That says "this device Cannot start Error Code 10" solutions I tried
1 Updating Ethernet Drivers
2 Rollback To old drivers
3 Disable/Enable The Device
4 From Bios Turning Off and on Lan option
5 Resetting Network
6 Turning Router Off/on
7 Changing Ethernet Cable
8 Installing Fresh Windows
These All Methods are Not working, at last I've Tried To update my bios From 0.0099 to 0.120 To see if That is Working or not And If I try to update bios And I try pressing f7 to to update my bios but Windows Logo Appears and It's looks like it's Stuck And Nothing Happens even after waiting 30+mins My PC information
CPU i7 3370
Ram 16 Gb
GPU Gtx 750 to
Motherboard DH61CR
Waiting For Your Response..
( Also I've Tried To Remove the yellow Jumper Near CMOS And Plugged My USB into Usb2.0 Port With BE0120.BIO, And when I turn on PC It's Displays Nothing
Muhadib
I've solved! With Rufus and a pen drive up to version 0048. The others need the recovery procedure, in particular the 099. Many thanks to Scott who provided me with the unobtainable version 0041 without which I would not have been able to go on.
n_scott_pearson
If you want to use Rufus to make a DOS-bootable flash drive, that's fine - but you must have reformatted the flash drive at least once using the Windows format applet, formatting for the FAT32 file system and ensuring that the Quick Format option is disabled. Once that is done, you can use Rufus and create a DOS-bootable image on the flash drive - but you must use the FAT32 file system.
MattVonGrimm
Thank you very much Scott, you are a gentleman and a scholar (I'm English, we talk like that).
I've done the format (not a quick format) for every flash update increment from 0016-0035 using FAT32 file system on a 1GB, USB 2.0 flash disk, to FAT32, using the F7 BIOS Update with nothing but the .BIO file on the disk, all have worked perfectly, (the BIOS shows 0035 now) - except when attempting to update from 0035-0041.
I folllowed exactly the same procedure when attempting to update from 0035-0041, then I got the error message I mentioned above.
Using the Recovery jumper, all I got was a black screen and no activity for 30 minutes, I did exactly the same with the USB disk, folloing your instructions to the letter and also tried a different port, to no avail and the same resulting error message if attempting to use the F7 BIOS Update.
I'm just not sure how to use Rufus to make a DOS bootable drive and the steps needed, including the files I'd need and how to update the BIOS using a DOS prompt, whether I'd need to change filenames or if I'd need an application on the bootable USB DOS drive in order to update the BIOS.
All I've managed to find online is how to use Rufus with an .ISO file to install Windows 10 from an 8+ GB flash drive, nothing about booting into a DOS environment, then flashing the BIOS from a Command Line Interface, so I'm completely in the dark as to what files I'd need apart from the BIOS files (that you provided a link to) and how I'd go about flashing the BIOS.
For some reason removing the jumper for Recovery does absolutely nothing, just a blank screen (monitor on standby) for 30 minutes (or longer) and no activity from the USB drive or any attached devices, it appears that they're not getting any power, but the fans are spinning, the Mainboard light is on and the power LED on the front of my case is on, but no activity or POST beeps.
I followed your instructions to the letter, as you said, yet unfortunately no joy.
I need to update the BIOS to at least 0046 (or 0048 from your BIOS package) in order to install an Intel Core i5-3750K or Core i7-3770K (I can't see the real difference or need to upgrade to a Core i7-3770K over a Core i3-3750K, it may have twice the amount of threads, 2MB more L3 Cache Ram and 100Mhz faster, but is 3 times the price (or more) on eBay, but it's not deal breakingly faster, unless I'm missing something and it's worth it?), all is irrelevant though unless I can update the BIOS, the most I can install is a Core i7-2700K, from my current Core i3-2100, but I'm sure without a BIOS update I won't be able to run a decent GPU (for its age).
Thank you for responding to my issue, I hope you can help.
Many thanks in advance sir, you are way more experienced than myself.
Matt.
n_scott_pearson
Hah! I am Canadian and I talk like that too (give or take a different accent). I was always getting grief from my U.S co-workers, especially when I said 'out and about' (the two words that seem to identify where my accent is from) or if I spelled it, for example, Colour instead of color.
For any flash disk, you need to do the format with Quick Format disabled. This was the only way that we figured out how to clear the problems created by the Linux-based bulk formatters used by the manufacturers. You only need to do this once; not every time you are going to flash a BIOS (regardless of method).
Now, as to method for building bootable DOS flash drive, after having done the above slow format, simply download and run Rufus (current version available is 3.21). Settings to change/verify: Device = Your device. Boot Selection = FreeDOS. Partition Scheme = MBR. File System = FAT32. Quick Format = checked. Click on START and away it will go. Click on Close at the end to terminate. That's it.
Now that you have the bootable DOS flash drive, copy the IFLASH2.EXE file, as well as the .BIO file you want to install, onto the flash drive. You are now ready to boot it on the board.
Once you have the flash drive booted, use command "IFLASH2 /pf XXX.BIO /rb", where XXX.BIO is the name of the .BIO file you want to install.
I have attached an updated version of the ZIP file that (now) include the iFlash2 executable and the associated read-me file.
Only additional information I can give you is to read the first section of the BIOS Release notes (the PDF file included).
Let me know how it goes...
MattVonGrimm
It was a lamentable faliure, I think the board is bricked.
I updated it from 0035- 0041, using Rufus, no problem, but I needed 0042 minimum to be able to use a 3rd Gen socket 1155 CPU, so I updated it to 0048, everything was fine.
I thought, "While I'm doing it, I may as well update the board to the latest BIOS, as that may cover any compatibility issues with anything else I may install", bad idea.
I updated to 0099, with the nice GUI and new splash screen.
That's where things went wrong.
If I'm quick, I can enter BIOS setup with F2, BIOS update with F7 and select boot device with F10, all of these options work, I can change and save BIOS settins, I can open the updater and select a boot device. as soon as I attempt to boot from anything, it freezes. If I start up and try to get it to boot from USB or SSD, it freezes, I pulled the drives, tried to boot to USB. Freezes.
Tried to update the BIOS from USB from 0099 to 0120 to see if that fixes things and allows me to boot from ANYTHING, Strange Error Message-
Flashing motherboard firmware:
Currrent revision:         BEH6110H.86A.0099.2012.1205.1807
Updating to revision:   BEH6110H.86A.0120.2013.1112.1412
Preparing  image for Intel(R) Management Engine firmware ... [done]
Preparing  image for BackUp Recovery Block firmware ... [done]
Preparing  image for Boot Block firmware ... [done]
Preparing  image for Recovery Block firmware ...[done]
Preparing  image for Main Block firmware ... [done]
Preparing  image for Graphic firmware ... [done]
Flashing image for Intel(R) Management Engine firmware ... FW Update Sample Application ERROR FwUpdateFullBuffer
[failed]
Flash update failed!
Technical Information:   (0x8000000000000015, 1632)
I don't know what this means apart from "This doesn't work"
I can't roll-back the firmware and the BIOS recovery jumper does nothing, if I bridge pins 1+2, normal boot, bridge 2+3 Configuration Boot into BIOS (then tells you to replace jumper on pins 1+2 after powering down before restart), remove jumper for supposed BIOS recovery, nothing happens, just a blank screen, I left it a number of times like this for 30+ mins, hoping it would do SOMETHING, but it's just a blank screen, it doesn't DO anything, which strikes me as odd.
The fans are spinning, the keyboard and mouse power up as well as the USB (my USB stick lights up when active) but the monitor remains in standby.
Like I said, I think the board is bricked, unless you know of a way to fix it, I've tried everything I can think, including trying to re-flash 0099, that just tells me that I'm already running 0099 so there's no need for an update.
I don't know what else to do, I think I've tried everything possible unless you know of something?
It's a real disappiontment, seeing as all I wanted was to update to take a 3rd Gen. CPU.
I may have to end up buying a used socket LGA 1155 board from eBay, any suggestions on a good one if I can't fix this?
I will need 4 SATA ports and probably onboard graphics for now, as I have yet to buy a GPU for that computer, and the ability to support at least 8Gb (16Gb would be nice) with at least two, preferably four DIMM slots, and compatible with DDR3 1333MHz and 3rd Gen. Core i3, i5 and i7 CPU's.
Looks like my "cheap living room PC project" from spares, has just become more costly.
Shame really,
Thanks for your help Scott, you've been invaluable, if you know what's wrong and how I can fix it, that'd be awesome, but I think it's probably dead. It'll let me enter the BIOS settings with F2, make and save settings, F7 for the flash utility, and F10 for the boot device menu, but as soon as you select a boot device or attemt to boot, it just freezes when you press (Y) to confirm booting from that device.
OR it just stays on the splash screen, progressing no further, not booting from any device and everything just hangs showing the Intel splash screen, I left it like this for almost an hour to see if it was just "being slow" because it was updating, but it wasn't and wont allow me to even boot into FreeDOS from USB or Windows from my SATA SSD.
Any suggestions or advice are welcome.
Matt.
n_scott_pearson
Did you follow the advice I gave in the original algorithm? That is, did you use the BIOS Recovery method for all of these updates? If you used any other method, you may have bricked the board. If you have a chance of recovering from this, reinstall BIOS 99 using jumper-based BIOS Recovery (i.e. Steps 7-22) and see if you can get the ME running again. Note: method for checking is to go into BIOS Setup, down into Advanced Information (or some title like that) scene and check the ME firmware revision (scroll down to bottom of information displayed). If it is 0000 or blank, then the ME is not running.
Crossing my fingers...
KenLau
hi teacher
I just up to BE0099 but cannot boot anyitem ,
I check ME is0000000
Please help
I try step 7~22 , jumper puted , screem black . wait 15min , restart ,
 & F2 , F9  Y , F10 Y
Same ME00000
AlHill
Start yourself a new thread, provide all information like, motherboard model, current bios, etc.
KenLau
DH61BE from BE0048 up to BE0099
n_scott_pearson
See my 02-06-2023 response. All you can do now is to try to do the jumper-based BIOS Recovery with the 99 BIOS. If it succeeds and the ME Firmware is not 0000 or blank, great, you got it back. If not, then you are permanently bricked and your only options are to find a flash image or discard the board.
Sorry, but this is the reality of the situation,
MattVonGrimm
Mine is completely bricked, I'm selling the CPU and tossing the board.
I bought a used Gigabyte Q170M-C instead with a Core i5-6500, unfortunately it has a custom BIOS (from 2015) so I'm just going to have to risk an offical update from Gigabyte so I can run a Core i7-7700k.
Thanks for all your help Scott, I'm sorry for not reporting back sooner.
Matt.
n_scott_pearson
According to the TPS for the DH61WW (page ii), the board utilizes the BE BIOS (i.e., BIOS BEH6110H.86A). The files that I provided are for the BE BIOS. It is certainly true that the DH61BE board also uses this same BIOS and it is certainly possible that there is a minor bug wherein the wrong name is used.
I don't have a board to try this with, so I cannot verify whether or not this issue is happening consistently. I will say that I do not believe this will affect the operation of the board, but let's look further. From the main BIOS Setup scene, cursor down and click on the Additional Information entry. Send me captures of the screens contents (it may take two shots to show it all).
edwin_r
Hi. Thank you for your response.
Now i had updated 4 motherboards DH61WW to 0120, and confirm the little bug that identifies this board as "DH61BE" when updated to 0099. But since 0120 update, it is identified correctly as "DH61WW", see attachments.
I have some minor observations about the recommended process to update, at least for this model. It could be useful for others trying to do the same.
1. First of all, the recommended "Bios Recovery" method WORKS. In the past, i did sucessfully updated to 0048 by the F7 method, but if you do the same when updating to 0099, YOU WILL BRICK YOUR MOBO, CONFIRMED. That's what happened to me in February this year, when i didn't know anything about this "Bios Recovery" method. (i ordered a mini programmer CH431A and finally rescued that mobo, long story). I would recommend to stick to the initial procedure Scott shared.
2. The posted process failed to me in 2 occasions. As others say in other forums, it could be a good idea to take off the CR2032 battery during ALL THE UPDATE PROCESS. (the no-battery warning won't interfiere at all). The idea is turning off the board completely after every update, so when i did the 8th and 14th pass of the guide, i even waited 'til the green led of the board goes off too, not only unplug the AC power cord from the wall.
3. When updating from 0048 to 0099, there wasn't a screen that asks you for turn off the board, (as when you update to 0048 or 0120). When the update 0099 is done, it says for 3 seconds "System will Reset", and won't wait for you. The first time, i couldn't get the Usb flash memory out of the board -it was so fast-, so it perfomed a new "bios recovery" that bricked my mobo, and didn't read the usb flash again, i realized, because USB flash memory didn't turn its led when the board was bricked. Fortunately i did a backup of the original Bios using a CH431A mini-programmer.
You MUST pay attention when performing the 0099 update, and turn off the board exactly when your system reboots after the "System will Reset" message AND TAKE OFF THE USB FLASH MEMORY (16th pass).
4. If you can, get a Bios programmer and backup before doing anything, just in case.
The DH61WW is a good board for office use and similar. Using it in w10 x64 v1703, with no ethernet problems.
Special thanks to Scott
Regards to all.
n_scott_pearson
Please do the following:
  1. From POST, use the F2 key to get into BIOS Setup.
  2. Scroll down to and select the Additional Information entry.
  3. Scroll down to the last item in the list.
  4. Take a photo of the screen and attach it to a response.
I am asking for this because you have a 6 Series motherboard that was primarily intended for use with 2nd gen processors. If you didn't install the BIOS upgrades correctly, you will still have the 2nd gen firmware running in the Management Engine and not that for 3rd gen processors. I want to see whether this is the case.
