The graphics settings in an ASUS BIOS can normally be found in the Advanced Mode part of the BIOS under the Advanced->System Agent (SA) Configuration->Graphics Configuration section.
The screenshot below shows the two settings involved
Primary Display is normally set to Auto but by default iGPU Multi-Monitor is set to Disabled. Set this to Enabled and the integrated graphics will then work.
