Community
cancel
Showing results for
Search instead for
Did you mean:
KKozi2
I would like to ask if in my processor Intel® Core ™ i5-6200U processor can increase the GHZ clocking or enable Turbo mode because I saw in the processor description that it can have a maximum 2.8 GHZ The processor is in a laptop
n_scott_pearson
Super User Retired Employee
Turbo Mode should be enabled by default. The BIOS controls this; use BIOS Setup to change - if it supports this being changed.
For more information (get ready to do a lot of reading; this isn't a simple thing), consult these sources:
Hope this helps,
