Processors
14537 Discussions
I would like to know the consequences of high usage of cpu (100% all cores) for long periods of time, at least 15 days.
SMode1
I need official information for the case of cpus intel X5670, 4650, 2695 and 2680 and xeon series.
Thank you in advance for your help.
Emeth_O_Intel
Hello, Thank you for contacting us about this concern. The consequences of a high usage of CPU (100% all cores) will be the following: A) You will not open multiple programs at once. B) Lagging Issues. C) FPS gets really lows. Pretty much slow performance of the system, may I know why are you looking for this information? Are you trying to accomplish an specific configuration? Please let us know the outcome in order to double check the information. Best regards, Emeth O. Intel Customer Support Technician. Under Contract to Intel Corporation.
SMode1
Hello. It is because we have a cluster and sometimes there are users that use the compute nodes with 100% usage of cpu for several days, like this one: Our infrastructure is composed by compute nodes that contains these processors: • CPU ITEL X5670 • CPU INTEL 4650 • CPU INTEL 2695 • CPU INTEL 2680 For this reason I am concerned about that and I was reading this forum that says this, that’s why I wanted to ask you about that: Therefore, I understand that in our case, the inconvenients are not critical. Kind regards for your help. Msc. Mercy Anchundia Ruiz. Especialista de TICS Tlf. +59322976300 EXT 1537 https://hpcmodemat.epn.edu.ec/ Síguenos en Twitter: @HPCModemat MODEMAT -EPN
Emeth_O_Intel
Hello, No problem, you are very welcome. Usually those processors are capable to support 100% CPU Usage on the cores. The processor will be affected in case of overclocking because it will decrease the life circle of the unit and it will cause an overheating issue as well. If you have any other question, please do not hesitate and let me know and I will be more than happy to assist you. Best regards, Emeth O. Intel Customer Support Technician. Under Contract to Intel Corporation.
Emeth_O_Intel
Hello, I would like to know if you have any other question in order to assist you with. If so, please do not hesitate and let me know and I will proceed with the next step. Best regards, Emeth O. Intel Customer Support Technician. Under Contract to Intel Corporation.
Emeth_O_Intel
Hello, I have not seen any activity on this thread since many day ago. So, I am going to proceed and close it. If you have any other question, please do not hesitate and contact us back and we will be more than happy to assist you. Best regards, Emeth O. Intel Customer Support Technician. Under Contract to Intel Corporation.
