Processors
16105 Discussions
I5 2400 showing insanely high Ghz
TooManyGhz_Help
what could cause this? faulty sensor? maybe a faulty cpu?
Im getting intermittent bluescreens when using the pc.
BSOD: KMODE_EXCEPTION_NOT_HANDLED
Caused by driver: ntoskrnl.exe
i've checked the ram, ssd and gpu, so it has got to be something with the cpu
AlHill
You want a 13-year oldd processor to run perfectly?  First, you are not supported.  Second, change the thermal paste and clean the cooler and fans.
TooManyGhz_Help
absolutely not!
Im just trying to figure out why it is showing 45 million ghz and what would cause task manager to make that reading
