i have intel Core i5-3470 . it gets 69 During Full load (Gaming Running Battlefield 4) anyway i noticed in intel website that my processor TCASE 67.4
So i am worried . is the processor in danger ? and i am using stock cooler what should i do !
Hi haleem22,
Thank you for sharing this with us. It is very important to know what the Tcase is and sometimes is difficult to understand the meaning so I will be more than glad to help you with this.
The TCase is a number established by Intel® as a point of reference in order to understand what could be expected as per normal processor temperature.
Anything from the Tcase and below will be the expected temperature of the processor in normal use, anything that doesn't stress out the processor (watching movies, burning CDs, browsing the internet, creating documents, etc.) When the processor is stressed out meaning that you are running heavy processor applications that take control of the CPU or uses it at 100% the temperature will go beyond the Tcase and it can perfectly reach 80 to 85 degrees and the processor will still be OK. The cooling fan is in charge to keep that temperature there.
If the processor temperature reaches 100 degrees or more it will send a signal to the motherboard to shut down to prevent mayor damages and most likely it won't be possible to turn the computer back in until it cools down.
The normal processor temperature will depend on the chassis type, the hardware involved and the location of the computer, and it usually is lower than the Tcase.
I hope you find this helpful!
Kevin M
