Processors
15864 Discussions
I7 10700 Resetting XTU to Default
PatTI7
Hello
When i was using Stock cooler i used XTU To keep Temps under control, have since upgraded Cooler to Arctic Freezer 7x,  don't believe i need the XTU Settings anymore with possibly a bit better cooler.
Do Not Wanna overclock, just run my I7 10700 as stock settings, and use as temps allow the included turbo boost at times only
How do i reset XTU to Default settings or do i simply uninstall it and remove it, and clean out the left overs?     as when i run intense programs, in Hardware monitor it shows Power limit exceeded, and such,  UEFI bios is at default already
Alberto_R_Intel
PatTI7, Thank you for posting in the Intel® Communities Support.
In reference to your inquiry, since the UEFI BIOS is at default settings already:
https://www.intel.com/content/www/us/en/support/articles/000055800/processors/processor-utilities-and-programs.html
You just need to uninstall the Intel® XTU application following the instructions on the link below:
https://www.intel.com/content/www/us/en/support/articles/000032459/processors/processor-utilities-and-programs.html
Albert R.
PatTI7
Ok Searched for XTUService (Not found) at all,  checked for the other directories, deleted 2 Intel XTU directories,  rebooted system,  so hopefully all is good now,  seems only had the 2 leftover folders in Program Files, and 1 in X86 area of Program files, otherwise i don't see any other XTU References left
Alberto_R_Intel
PatTI7, Thank you very much for letting us know those details.
Perfect, that should be enough for you to be able to use your Intel® processor at stock configuration with the default BIOS settings.
Albert R.
