Olá, prezados.
meu novo processador I7 13ª esta aquecendo muito em testes de stress, não sei se isso é comum, mas estou com medo de realizar tarefas pesadas como edição de vídeo.
estou usando Water Cooler Gigabyte Aorus Waterforce 360 Argb 360mm.
estou enviando alguns testes realizados com ferramentas da própria Intel para análise.
AguinaldoBarreiro, Thank you for posting in the Intel® Communities Support.
Só para informar, oferecemos suporte apenas em inglês e, atualmente, estamos usando uma ferramenta de tradução.
We will be more than glad to assist you with this matter.
In reference to your question, yes, it is common for the temperature of the processor to increase while running a stress test since you are forcing the unit to perform at its maximum capacity.
The T-junction of the Intel® Core™ i7-13700KF processor is 100°C, any temperature value lower or equal to that value is considered normal and expected for this unit:
In order to rule out a possible hardware problem with the processor, install and run the Intel Processor Diagnostic Tool, it does an overall test on the unit and if it passes the test it means it is working properly:
Here you have the "Overheating Symptoms and Troubleshooting for Intel® Boxed Processors", for you to be able to confirm if in fact the processor is getting overheated:
We also recommended to get in contact directly with AsRock Support to make sure the latest BIOS version is currently installed on your machine, or to gather the instructions on how to update it:
https://www.asrock.com/support/
Albert R.
Hello AguinaldoBarreiro, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
Hello AguinaldoBarreiro, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
