I recently upgraded my RAM to 16GB. Su8bsiquently, I receive frequent processor Temp warnings. They advise processor temp is 72c. This is on an Asus P8Z68-V board. Should I be concerned and if so, what would be a recommended solution to this issue?
Hello tpb001739,
Thank you for contacting Intel Communities.
In this case, I would recommend checking the following:
- You have the latest BIOS.
- The max RAM speed is DDR3 @1333 MHz.
- The memory that you installed is compatible with the motherboard.
- https://www.asus.com/Motherboards/P8Z68V/HelpDesk_QVL/ Memory/Device Support - Asus
- Run the https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool Intel Processor Diagnostic Tool to see if the processor passes the test.
You can also check the articles below for more information regarding overheating:
http://www.intel.com/content/www/us/en/support/processors/000005597.html Frequently Asked Questions about Temperature for Intel® Desktop and Mobile Processors
http://www.intel.com/content/www/us/en/support/processors/000005791.html Computer Is Overheating Warning Signs
Please let me know how it goes.
JC
Downloaded that processor tool. Thanks for your help JC. It shows all is well.
Hello tpb001739,
You are welcome.
Please don't hesitate in contacting us back if you need further assistance.
JC
Topic Options
