Processors
14774 Discussions
I7 3740qm chipset compatibility
Unorthodox
Does this processor support hm75 chipsets? The intel specifications webpage for the i7 3740qm is missing the compatible products section for the chipsets.
n_scott_pearson
It should be supported. Now, using an i7-3740qm with an existing system is a separate question. Processor has to be socket, chipset and BIOS compatible. That is, the BIOS must include support for this particular processor.
Hope this helps,
n_scott_pearson
Hope this helps,
Unorthodox
Hi, yes I have checked and the sockets are compatible, unfortunately bios compatibility for laptops doesn't seem to be 'shared information' so I can only guess if TDP draw will be an issue until I try. Cheers for the information:)
