Processors
14534 Discussions
I7 4790k heats up to 90c when in use
JGros9
I recently got a CPU temperature program which detects and tell me what my CPU temperature is, as I used it I discovered when using 40%-100%, it would bring the temperature up to 90c. I have had this processor for a year and I'm not sure what to do. Will this have damaged my CPU if I've been using it at 90 degrees Celsius for the last year?
Specs:
Processor: I7-4790K LGA1150
Motherboard: Z97X-Gaming-7
Power Supply: Corsair CX750 watt
256 SSD
2tb Hard drive
Graphics Card: Gigabyte GTX 970 wind forcer
Case: Thermaltake V3 Black
IUman
Hello jjgrosk008,
Thank you for joining the Intel communities.
You may want to check the following thread:
/docs/DOC-23517 https://communities.intel.com/docs/DOC-23517
This thread talks about CPU over heating with this Intel® processor and how some customers have been able to solve this over heating issue.
Ivan
