Hello,My processor heats up abnormally.
Temperatures fluctuate completely randomly.
One heart can be found at 18 degrees and another at 58 degrees.
And in the second I am the reverse.
Thanks in advance for your help.
Bonjour,
Mon processeur chauffe anormalement.
Les températures fluctuent de manière totalement aléatoire.
On peut trouvez un cœur a 18 degrés et un autre à 58 degrés.
Et dans le seconde qui suis c'est l'inverse.
Merci à l'avance pour votre aide.
I have noticed the processor is currently based on the picture at 41 C, this means the processor is running under normal conditions.
I did see one of the processor cores running higher temperatures than others but this is expected. There is always one core running hotter.
Additionally, I recommend running the https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool processor diagnostic tool, this will run diagnostics and let you know if the processor is running in good condition.
Allan.
Were you able to test the Intel® processor diagnostic tool?
Allan.
