Hi all,
Just upgraded my PC, the specs are:
I7-6700K
Asus Z170 MKI
Radeon R9 280x
Corsair 2400Mhz DDR4
Win 7 Ultimate 64x
Corsair 750W Bronze
H60
Having issues where when running idle, CPU usage spikes randomally upto 20%, esp when loading programs it can hit the high 40's (no programs in specific causing the load, just whatever is open/running will spike; including svchost etc). Playing any game almost immediately tops out the CPU at 100%. All drivers and updates installed, new install. Any idea's why this is happening? Poss defective chip? Temps are okay, higher than I expected when idling though.
Also maybe worth noting that the CPU voltage was set to 1.37V upon install without any changes to bios etc, forcing this to 1.2V improved usage slightly.
Many thanks.
Edit: After checking CPU-Z it seems as if my core speed is jumping between 800 and 4000 every second with corresponding voltages going from 0.7V to 1.37V. I understand this happens when under load, but the PC is idle.
Message was edited by: James Hale
Look in Task Manager, especially the Processes tab, where you will probably discover that you have some over-active processes.
Hi Paramountain,
I am checking the Task Manager, this is where I am supplying the above info from. It's more the case that it shouldn't be doing this at all CPU usage all round should be lower and certainly not maxing out on all games when my prev AMD processor handled it just fine. Do you have any suggestions as to why it could be doing this? Should I try reseating the CPU (can it cause this issue)?
Usually I would follow a process of elimination and replace parts to see what is causing the issue, but this is my first changeover to Intel, so I don't have a spare 1151 Socket mobo/cpu lying around to test.
It should be noted that it has passed the Intel Processor Diagnostic Software, however, I am still experiencing these issues.
Cheers
I have seen issues like yours where an anti-virus or other application is a little too eager. You mentioned swapping parts; if you have a spare drive, I suggest disconnecting your current drive(s) and installing Windows on the new one. Don't activate it via Microsoft, but install all usual updates and your testing tools. Then test. Add a game or whatever causes the problem and test.
But before you do that, reinstall your CPU cooler and make sure it is properly seated with the proper amount of thermal compound. I say this because of your comment that temperatures are "higher than I expected when idling."
Also, your comment that "corresponding voltages [are] going from 0.7V to 1.37V" could point to a PSU problem. Or it could be the motherboard. Or it could be the CPU as you suspect. Do you have a spare PSU with which to test?
--- IPDT64 - Revision: 3.0.0.25.W.MP
--- IPDT64 - Start Time: 10/03/2016 12:25:03
Processor 1
Intel(R) spbc Module Test
Module Version: 1.0.7.64b.W
Start Time: Thu Mar 10 12:25:03 2016
Test Result - PASS
..!!..Processor under test is verified as 'PRODUCTION'..!!..
Processor Manufacturer: GenuineIntel
Processor Brand String: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
End Time: Thu Mar 10 12:25:03 2016
Total Time: seconds: 0
Genuine Intel CPU Test
Module Version: 1.0.12.64b.W
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
Temperature Test
Test Result - PASS
Expected: Greater than 1 degrees below max
Received: 65 degrees below max
CPU Brand String Test
Test Result - PASS
Expected String Parts: As Defined in BrandString_LocalConfig.xml
Detected: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
CPU Frequency Test
Module Version: 1.0.14.64b.W
Test Result - PASS
Processor Name: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
Expected CPU Frequency: 4.00
Detected CPU Frequency: 4.00178
Expected Base Clock: 100
Detected Base Clock: 100.044
QPI link rate Test - Not supported.
Skipping QPI link rate Test.
End Time: Thu Mar 10 12:25:04 2016
Total Time: seconds: 1
Floating Point Test
Module Version: 1.0.10.64b.W
Start Time: Thu Mar 10 12:25:04 2016
Test Result - PASS
Million Floating Points per Second, MFLOPS: 604.8
Error: 0
--- Floating Point Test Passed!!!---
End Time: Thu Mar 10 12:25:06 2016
Total Time: seconds: 2
Prime Number Generation Test
Start Time: Thu Mar 10 12:25:06 2016
Test Result - PASS
Operation Per Second: 5.31663e+006
Error: 0
--- Prime Number Generation Test Passed!!!---
End Time: Thu Mar 10 12:25:08 2016
Cache Test
Start Time: Thu Mar 10 12:25:08 2016
Test Result - PASS
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 32
- Detected L1 Inst Cache Size --> 32
- Detected L2 Cache Size --> 256
- Detected L3 Cache Size --> 8192
Cache Size Test Passed!!!
MMXSSE Test
Test Result - PASS
--- Determining MMX - SSE capabilities ---
--- CPU FEATURES DETECTION FOR ---
--- MMX SSE ---
MMX - MMX Supported --> Yes
SSE - SSE Supported --> Yes
SSE2 - SSE2 Supported --> Yes
SSE3 - SSE3 Supported --> Yes
SSSE3 - SSSE3 Supported --> Yes
SSE4.1 - SSE4.1 Supported --> Yes
SSE4.2 - SSE4.2 Supported --> Yes
--- MMX SSE - capabilities check complete ---
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
AVX Test
Module Version: 1.0.11.64b.W
Test Result - PASS
--- Determining AVX AES PCLMULQDQ capabilities ---
--- AVX/AES/PCLMULQDQ ---
AVX - Advanced Vector Extensions Supported --> Yes
AVX OS Support - AVX Operating System Supported --> Yes
AES - Advanced Encryption Standard Supported --> Yes
PCLMULQDQ - Polys Carry-Less Multiply Supported --> Yes
--- AVX AES PCLMULQDQ capabilities check complete ---
AVX Compare Test Result --- PASS
AES Test Result --- PASS
PCLMULQDQ Test Result --- PASS
IMC Test
Start Time: Thu Mar 10 12:25:09 2016
Test Result - PASS
--- Reading Memory Size ---
Detected Memory Size is --> 16.00GB
--- Subtest - Memory Size Test Passed!!! ---
--- Integrated Memory Controller Stress Test ---
Memory to be allocated = 1048576 byte
Memory Allocated.
Test 1 Ones and Zeros Moving Inversions write operations - Passed
Test 1 Ones and Zeros Moving Inversions verification operations - Passed
Test 2 32Bits Sliding Ones write operations - Passed
Test 2 32Bits Sliding Ones verification operations - Passed
Test 3 32Bits Sliding Zero write operations - Passed
Test 3 32Bits Sliding Zero verification operations - Passed
Memory Deallocated.
--- Subtest - Memory Stress Test Passed!!! ---
Integrated Memory Controller Stress Test Passed!!!
End Time: Thu Mar 10 12:25:09 2016
PCH Test
Module Version: 1.0.9.64b.W
Test Result - PASS
Chipset : Skylake Platform Controller Hub
No device connected to PCI Express Port 1
No device connected to PCI Express Port 9
1 device conne...
