Our customers use the I7-6900K chip for development and design, but this chip has been discontinued.
I see that the slot supported by I7-6900K is FCLGA2011-3. I used the advanced search function and found that the recommended chips are all XEON series chips. Do you have CORE series chip recommendations? Hope the pin to pin is compatible.
Or do you have any other suggestions, thank you
It is not just the socket you need to be concerned with. You must also be concerned with chipset compatibility, and that the BIOS will support the replacement processor.
Doc
