Processors
14539 Discussions
I7-7700HQ Temperature - Is this temperature right?
LBaD
Hello, I've been with a laptop for a week, with the i7-7700HQ processor and I have doubts about the temperatures.
Playing I have reached 96/98 degrees in one of the cores and I do not know if that is right or wrong. I did the test with the IntelProcessor Diagnostic Tool and in all the tests gave an average of 40 degrees below the maximum these are the results of the test. . Everything is alright ?
--- Temperature Test ---
Version 1.0.17.64b.W
Entering run forever
Current Junction Temperature is 50C
Current Degrees Below Max 50C
Maximum Junction Temp Allowed 100C
Test Result - PASS
Expected Greater than 1 degrees below max
Received 50 degrees below max
Test PASSED
Current Junction Temperature is 84C
Current Degrees Below Max 16C
Test Result - PASS
Received 16 degrees below max
Test PASSED
Current Junction Temperature is 85C
Current Degrees Below Max 15C
Test Result - PASS
Received 15 degrees below max
Test PASSED
Current Junction Temperature is 87C
Current Degrees Below Max 13C
Test Result - PASS
Received 13 degrees below max
Test PASSED
Current Junction Temperature is 56C
Current Degrees Below Max 44C
Test Result - PASS
Received 44 degrees below max
Test PASSED
Test Result - PASS
Test PASSED
Current Junction Temperature is 64C
Current Degrees Below Max 36C
Test Result - PASS
Received 36 degrees below max
Test PASSED
Current Junction Temperature is 70C
Current Degrees Below Max 30C
Test Result - PASS
Received 30 degrees below max
Test PASSED
Current Junction Temperature is 71C
Current Degrees Below Max 29C
Test Result - PASS
Received 29 degrees below max
Test PASSED
Current Junction Temperature is 73C
Current Degrees Below Max 27C
Test Result - PASS
Received 27 degrees below max
Test PASSED
Test Result - PASS
Test PASSED
Current Junction Temperature is 54C
Current Degrees Below Max 46C
Test Result - PASS
Received 46 degrees below max
Test PASSED
Current Junction Temperature is 78C
Current Degrees Below Max 22C
Test Result - PASS
Received 22 degrees below max
Test PASSED
Current Junction Temperature is 82C
Current Degrees Below Max 18C
Test Result - PASS
Received 18 degrees below max
Test PASSED
Current Junction Temperature is 59C
Current Degrees Below Max 41C
Test Result - PASS
Received 41 degrees below max
Test PASSED
Current Junction Temperature is 55C
Current Degrees Below Max 45C
Test Result - PASS
Received 45 degrees below max
Test PASSED
Current Junction Temperature is 80C
Current Degrees Below Max 20C
Test Result - PASS
Received 20 degrees below max
Test PASSED
Test Result - PASS
Test PASSED
Test Result - PASS
Test PASSED
Current Junction Temperature is 57C
Current Degrees Below Max 43C
Test Result - PASS
Received 43 degrees below max
Test PASSED
Test Result - PASS
Test PASSED
Current Junction Temperature is 79C
Current Degrees Below Max 21C
Test Result - PASS
Received 21 degrees below max
Test PASSED
Current Juncti...
Hello Nalus,
I was taking a look to your thread and I understand that you want to know if the temperature of your I7-7700HQ is right or not.
It will be more than pleasure to help you out with your inquiry.
Based on the results that you shared I was able to check that the highest temperature that your machine reached was about 87°C. The maximum temperature allowed at the processor die will be 100°C. Our Intel Processor Diagnostic Tool performs a pretty detailed stress test that will take a processor to its highest temperature. Depending on the status of the processor, the highest temperature will change. Bad processors usually reach almost the top temperature, causing the whole system to crash, to go BSOD or to perform random reboots.
If your machine has any of these behaviors, I strongly recommend you to check this troubleshooting list:
https://www.intel.com/content/www/us/en/support/articles/000005776/processors.html https://www.intel.com/content/www/us/en/support/articles/000005776/processors.html
If you purchased your computer from a computer manufacturer opening your computer case may void your warranty. Contact your manufacturer if you are experiencing any overheating warning signs before trying any of these steps.
At this point I can totally assure that your machine has the right temperature, however if you run into any issues or performance error, you are totally free to let us know or to contact your OEM manufacturer in order to get support.
I hope this helps,
Diego S
