Hello, i got a i7-7700k and when i am gaming its always very hot around 80-95C
It start with 80C and within 10 minuts its 90+ and stays that hot.
Not overclocked and changed thermal paste and nothing worked.
Is it normal for a 7700k to become this hot with custom watercooling?
I7-7700K
Thermaltake W5 CPU water block
EKWB Pump D5
Asus strix Z270E
g-skill 32gb ram
Hello SBoor1
Thank you for posting in the Intel Community.
The Intel® Core™ i7-7700K can work up to 100C (tjunction) and it needs a cooling solution that dissipates a minimum of a Thermal Design Power (TDP) of 91 W (Intel® Core™ i7-7700K Processor specifications: https://ark.intel.com/content/www/us/en/ark/products/97129/intel-core-i7-7700k-processor-8m-cache-up-to-4-50-ghz.html). I recommend confirming with the consoling solution manufacturer that the model that you are using can handle these requirements.
Is the system reporting any error?
Please run the Intel® Processor Diagnostic Tool (https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool) and provide me with the .txt file report
Is the system BIOS up to date?
Is the system running on the default BIOS setting?
In case you need assistance to complete BIOS updates please contact ASUS* (https://www.asus.com/support/).
Hope this helps.
Leonardo C.
Under Contract to Intel Corporation
How old CPU is (when it was made)?
What TIM (thermal solution\paste\LM) are you useing on CPU?
Maybe stock TIM between CPU die and IHS is degradated and now not working at all.
