Good morning, I have a question about the size of the I7 8550U and the I7 12700K - I mean, what dimensions do these processors have of that grey area where you put the thermal paste/thermopad suitable for this (in English it is called silicon die I think but I am not sure).
I'm asking because I want to replace the thermal paste with a good thermopad (the kind used for this, not a regular thermopad)
Thank you and best regards
Hello @123zgadujty
Based on the public information available, the sizes can be found on the datasheet of the CPU, i7-8550U Datasheet, and i7-12700K Datasheet.
On page 103 of the 12 Gen CPU, you can see the dimensions of the CPU Integrated heat spreader (HIS): 40.29mmx36.5mm; on page 203 the document says for specific dimensions (die size, die location, and so on), refer to the processor package mechanical drawings. Unfortunately, the mechanical drawings for Intel® Processors cannot be shared. Also, refer to page 201 Package Mechanical Specifications.
In case of more specific information, refer customers to Resource & Documentation Center (RDC) for detailed information and create a premier account if needed. RDC offers Intel confidential content, pre-release product info, design tools, and project support.
In the case of the 8th Gen page 15 provides the following information:
The processor is available in the following packages:
• A 46 mm x 24 mm BGA package (BGA1528) for U-Processor Line
• A 42 mm x 28 mm BGA package (BGA1440) for H-Processor Line
• A 37.5 mm x 37.5 mm LGA package (LGA1151) for S-Processor Line
Let me know if you need something else.
Isaac Q.
Hello 123zgadujty,
We hope you are doing fine.
Let us know if you still need assistance. Otherwise, we will close this thread.
Isaac Q.
Hello 123zgadujty,
Best regards.
Isaac Q.
