Processors
All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
14265 Discussions
I7-8700 제품을 사용중인데 온도가 너무 높습니다
네이
CPUID의 HWMonitor 프로그램을 사용하여 평상시 온도를 확인해보면 45~50도 사이입니다.
문서작업과 인터넷 사용 중에는 충분히 괜찮습니다만...
언리얼엔진4 혹은 고사양 게임(몬스터 헌터 월드)를 할 때면
CPU 점유율이 40~50%, cpu 공급 전력은 1.2 V로 나오며 온도는 85~100도를 왔다갔다합니다.
쿨러 장착에 문제가 있나 싶어 확인해보고 서멀 구리스도 ARCTIC사의 MX4 제품을 구매하여 새로 도포했는데도 결과는 같았습니다.
CPU 점유율이 30%만 넘어가도 80도가 훌쩍 넘어가버립니다.
현재 기본 쿨러를 사용중인데 사제 쿨러를 새로 구매해야할까요?
혹은 드라이버 설치 후 설정을 바꾸어서 해결할 방법이 있을까요?
Hello leeneko,
Thank you for joining the Intel Communities.
It is expected the CPU may reach high temperatures while gaming.
Does the system shut down when the computer reaches 100 degrees Celsius?
Do you notice any performance issues when the CPU reaches high temperatures?
Please run the following utility and attach the results to this thread https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool
I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .txt file the Intel® System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
May I have the part number of the RAM memory you are using in your computer?
To attach a file, you must click "Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
Fred D.
Under Contract to Intel Corporation
Hello leeneko,
I was wondering if you still need assistance regarding the overheating issue you were having. In case you still need assistance just let me know.
Fred D.
