Processors
16110 Discussions
I7-9700k avg temps & spikes
qlemens
Hello
I would like know if I should worry about temperature spikes on my CPU. Average temps after consecutive Total War Three Kingdoms benchmark run end with value below 80 C. However sensors detect spikes up to 95 C (very short temp rise). CPU is not OC. Motherboard Gigabyte Z390 Aorus Pro. Cooler is AiO - Asus ROG Strix LC 240
n_scott_pearson
When under load, seeing average temperatures in the 80's and only short-duration spikes into the 90's is perfectly normal and acceptable.
qlemens
Default BIOS settings, CPU_OPT port set to normal (default). XMP Profile 1.
n_scott_pearson
qlemens
That's what I hoped for. Thanx for your help.
