Anybody knows how to fix it?
Hello Dato255,
- When did you purchase the processor?
- Was it working fine before?
- Are you running on default settings?
- How can you disable and enable the Cores 7-8 if you are not getting display on the screen?
Michael L.
Hello Dato255,
Please try the following:
Try to clear the CMOS
- Start with the minimal hardware in your system, such as power supply, one DIMM of memory.
- Clear the CMOS (complementary metal-oxide-semiconductor). Review instructions on how to clear the CMOS.
Try another motherboard
- If there are no lights on the motherboard, try to use a different working motherboard if you have one.
Update the BIOS if you have 13th Gen Intel® Core™ and Intel® 600 Desktop Series Chipsets
- The 13th Generation Intel® Core™ Processors are based on socket LGA1700, and they are compatible with Intel® 700 Desktop Series Chipsets (Z790, H770, B760) and the Intel® 600 Desktop Series Chipsets (Z690, W680, Q670, H670, B660, H610). However, the Intel® 600 Desktop Series Chipsets will need to be updated with the latest BIOS version. Refer to your motherboard vendor for support.
If the system worked before, revert changes
- Determine if there have been any recent changes. Often if a change is made, that recent change is the cause of the problem. If there were any hardware changes, revert the changes.
Try to load BIOS default settings
- Try to enter the BIOS and load the default settings. Contact your motherboard vendor for information about resetting BIOS to default settings
Other tips to consider
- Try to use another working processor if you have. For swap testing scenarios and recommendations, you can visit How to Troubleshoot an Issue by Swapping between Processors.
- Check for visibly bent or broken pins on the motherboard. Physical damage may affect optimum functionality of the processor.
- Check if the front panel header connector is firmly plugged into the board.
- Check cable connections for monitor, power supply, and fans.
- Check the monitor for video input selection: VGA, DVI, HDMI, or USB-C.
For step-by-step troubleshooting, you can use the No Boot/No Display Wizard at Intel® Desktop Boxed Processors – No Boot/No Display Troubleshooting Wizard.
Here's the link for reference:
Troubleshooting for No Boot and No Display Issues with Intel®...
Dean R.
Hi Dato255,
We are following up to find out if you experience any issues.
We weren't able to get any response from you regarding the needed information.
Dean R.
Hi Dato255,
Dean R.
