Processors
13880 Discussions
I9 12900KF win10系统下 。在maya中执行python,maya就会闪退。测试过不是系统的和maya版本的问题。
刘继泽
I9 十代不会出现这种问题 。
例如在maya中运行studiolibrary这个插件 一运行就闪退  只要是python写的插件maya都会闪退
JosueO_Intel
Hello 刘继泽,
Thank you for posting on the Intel communities. Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
In order to have a better understanding of the issue, please share with us the following information:
  1. Small video of the issue.
  2. Is this for a developing project?
  3. Have you reported this issue to the application developers?
Josue O.
刘继泽
测试过maya2018  maya2020 都是用打不开插件   但是安装了maya2022,就可以了。
可能是I9 12900KF 对python2.7不兼容的问题吗? 因为maya2022兼容了python3.8
录了一段视频看一下
JosueO_Intel
Hello 刘继泽,
Josue O.
JosueO_Intel
Hello 刘继泽,
In this case, our recommendation is to first contact Autodesk and validate with them their older versions of the software with newer gen processors. After investigation with Autodesk, if needed, they can contact us directly to check the functioning between the app and the processor.
Hope this information is useful, if you need any additional information, please submit a new question as this thread will no longer be monitored.
Josue O.
