Today I want to tell you my story. I have a corsair brand cpu, it is the i8200 model, it already includes 64gb of ram, 4tb ssd and the rtx 4090 and the famous i9 14900kf, the problem started a few months ago and got worse over time. It all started when the games started to close without any explanation or reason over time some do not open like need for speed unbound and when it opens it is because I tried a thousand times and it opens and a blue screen will appear and the pc will restart. Another problem has happened to me with low memory messages and things like that from the system that seems to deceive that it is the graphics card but that is not the problem. Many times I formatted windows thinking that that would solve the problem but it did not. I uninstalled many programs and did a thousand things on the pc so powerful that it is not necessary to do anything to it, this was ridiculous. I contacted corsair they sent me a new cpu under warranty. I downloaded a program that stresses the cpu to 100% when I do it and open need speed unbound which is the game that shows me the most blue screens, well I tell you that the game can be played without any problem and with that I was able to verify that it is the cpu, the cpu passes the stress test well but it is when the cpu is at less than half of its use that it presents this type of problems, so read on I will let you know that if you have the same problem as me, test your cpu to the maximum with a stress test and play and you will see that it is solved but this will cause overheating and slowness in the games and I will tell you something this damage is permanent there is no solution only replace the processor there is nothing else to do
PROCESSOR
INTEL CORE i9 14900K
MEMORY
64GB CORSAIR DOMINATOR TITANIUM DDR5 6600MT/s
MOTHERBOARD
Z790 DDR5
COOLING
CORSAIR iCUE H150i ELITE CAPELLIX
GRAPHICS CARD
GEFORCE RTX 4090
STORAGE
CORSAIR 4TB (2x 2TB NVMe SSD)
POWER SUPPLY
CORSAIR 1000W 80+ GOLD
FULLY MODULAR
PROCESSOR
MEMORY
MOTHERBOARD
Z790 DDR5
COOLING
GRAPHICS CARD
GEFORCE RTX 4090
STORAGE
POWER SUPPLY
FULLY MODULAR
