Hello Bignoodle24,
Thank you for contributing to the Intel Communities. I appreciate you sharing the workaround or fix that was successful for you. I understand that you have implemented the recommended Intel settings for power voltage, and have disabled Turbo Boost and Turbo Boost 3.0 in the BIOS settings.
Our investigation suggests that updating to the latest microcode and reverting to "Intel default settings" should address the issue. Please contact your motherboard manufacturer's support for further assistance.
If the issue continues, we are offering a replacement. You can submit your request at Intel Support Tickets.
Feel free to reach out if you have any questions or need further clarification.
JeanetteC.
Hello Bignoodle24,
I understand and have noted your situation. You mentioned that your system is functioning well after disabling Turbo Boost in the BIOS setup. Are there any current issues that we should be aware of?
JeanetteC.
Hello Bignoodle24,
I'm reaching out to see if you've had the opportunity to review my previous message. If you have, please confirm receipt, and feel free to contact me if there are any points you'd like to discuss or need further clarification on.
JeanetteC.
