Processors
14538 Discussions
I9-9900 (non-k, 65w) is soldered or not? (1151v2)
LLabu
for example in i5-9400f​ use TIM and i9-9900K use STIM. And i not sure for i9-9900 what uses?
n_scott_pearson
I presume that you are asking about the i9-9900 (there is no i5-9900) and whether this part uses TIM or solder to dissipate heat from its silicon to its heat spreader. The answer is yes, the part utilizes solder. In fact, all of the 9th gen. i5/i7/i9 processors use solder.
LLabu
I know 100% for example in i5-9400f​ use TIM and i9-9900K use STIM. And i not sure for i9-9900 what uses? Please answer me
AlHill
Or,is the OP asking about the socket type?
Doc
n_scott_pearson
Intel's formal statement (see here) is "Unlocked 9th Gen Intel® Core™ i5, Intel® Core™ i7 and Intel® Core™ i9 processors are built using Solder Thermal Interface Material (STIM)". I presume from this that locked SKUs will retain TIM.
LLabu
