Processors
16311 Discussions
INTEL CELERON D 340 COMPATIBILITY ISSUE
Recently my intel proccesor was damaged, it is a celeron 340 D SL7TS. My inquiry is can I use a similar processor but with a different SPEC Code such as 340 D SL7Q9, or SL7RN....etc....
Thanks for the help
It all depends whether the board suports it or not and also the bios.
Even on some intel boards, different cpu with different sl number are not validated, actually this may invalidate your warranty as it is not operating under recommended conditions.
Make sure to check from the board manufacturer.
All the best,
Kind Regards,
Aryan.
Thank you Aryan, I'm not too concerned about invalidating the warranty, the Intel motherboard is over 5 years old. But to be on the safe side ,I'll purchase a processor with the same SL # ....Thanks for the response
All the best with your new CPU.
If you dont have any questions, may be you can mark this question as answered.
Kind Regards,
Aryan.
