Processors
16021 Discussions
IS THIS A FAULTY PROCESSOR? WHEA_UNCORRECTABLE_ERROR (124) PROCESSOR: INTEL PENTIUM D 920 D 2.80 GHZ NORMALLY CRASHES TOWARDS THE END OF A DEFENDER ANTI-VIRUS SECURITY SCAN
PPatt3
MACHINE ORIGINALLY XP - NOW WIN 10 PRO - USING WIN XP CHIPSET DRIVERS?
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 00000000, Machine Check Exception
Arg2: 9201f024, Address of the WHEA_ERROR_RECORD structure.
Arg3: b2000000, High order 32-bits of the MCi_STATUS value.
Arg4: 1040080f, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
KEY_VALUES_STRING: 1
   Key : Analysis.CPU.Sec
   Value: 11
   Key : Analysis.DebugAnalysisProvider.CPP
   Value: Create: 8007007e on WIN10PC
   Key : Analysis.DebugData
   Value: CreateObject
   Key : Analysis.DebugModel
   Value: CreateObject
   Key : Analysis.Elapsed.Sec
   Value: 14
   Key : Analysis.Memory.CommitPeak.Mb
   Value: 55
   Key : Analysis.System
   Value: CreateObject
BUGCHECK_CODE: 124
BUGCHECK_P1: 0
BUGCHECK_P2: ffffffff9201f024
BUGCHECK_P3: ffffffffb2000000
BUGCHECK_P4: 1040080f
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
PROCESS_NAME: MsMpEng.exe
BAD_STACK_POINTER: 8883c074
STACK_TEXT:
8883c070 81249c70 00000124 00000000 9201f024 nt!KeBugCheckEx
8883c0a0 814f7b46 8921d620 9201f144 873f5960 hal!HalBugCheckSystem+0x6d
8883c124 8124b23e 873f5910 00000000 873f5910 nt!WheaReportHwError+0x319
8883c248 8124b4be 00000001 00000000 00001388 hal!HalpMcaReportError+0x53
8883c270 8124b3d9 00000001 00000000 00000002 hal!HalpMceHandlerCore+0xcf
8883c298 8124b5b1 88880000 00000000 00000000 hal!HalpMceHandler+0x52
8883c2b0 8124ad3c 00000000 00000000 00000000 hal!HalpMceHandlerWithRendezvous+0xb3
8883c2c0 8124bb81 88880000 8883c3f0 00000000 hal!HalpHandleMachineCheck+0x3f
8883c3e4 813f9965 00000000 0f0f0f0f 0f0f0f0f hal!HalpMcaExceptionHandler+0x8f
8883c3e4 69d1b2cb 00000000 0f0f0f0f 0f0f0f0f nt!KiMcaExceptionHandlerWrapper+0x2d5
WARNING: Frame IP not in any known module. Following frames may be wrong.
0339c880 00000000 00000000 00000000 00000000 0x69d1b2cb
MODULE_NAME: GenuineIntel
IMAGE_NAME: GenuineIntel.sys
STACK_COMMAND: .thread ; .cxr ; kb
FAILURE_BUCKET_ID: 0x124_GenuineIntel_PROCESSOR_BUS_LG_SRC_ERR_*_NOTIMEOUT_STACKPTR_ERROR
OS_VERSION: 10.0.18362.1
BUILDLAB_STR: 19h1_release
OSPLATFORM_TYPE: x86
OSNAME: Windows 10
FAILURE_ID_HASH: {b67df69e-a1ab-d4a0-edea-83bbe929dc64}
Followup:    MachineOwner
WARNING: Process directory table base 7D8609C0 doesn't match CR3 001A8000
1: kd> !errrec 9201f024
Common Platform Error Record @ 9201f024
Record Id    : 01d57911bed8e4af
Severity     : Fatal (1)
Length       : 936
Creator      : Microsoft
Notify Type  : Machine Check Exception
Timestamp    : 10/2/2019 18:22:36 (UTC)
Flags        : 0x00000000
Section 0    : Processor Generic
Descriptor   @ 9201f0a4
Section      @ 9201f17c
Offset       : 344
Length       : 192
Flags        : 0x00000001 Primary
Severity     : Fatal
Proc. Type   : x86/x64
Instr. Set   : x86
Error Type   : BUS error
Operation    : Generic
Flags        : 0x00
Level        : 3
CPU Version  : 0x0000000000000f62
Processor ID : 0x0000000000000001
Section 1    : x86/x64 Processor Specific
Descriptor   @ 9201f0ec
Section      @ 9201f23c
Offset       : 536
Length       : 128
Flags        : 0x00000000
Severity     : Fatal
Local APIC Id : 0x0000000000000001
CPU Id       : 62 0f 00 00 00 08 02 01 - 3d e4 00 00 ff fb eb bf
               00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00
Proc. Info 0 @ 9201f23c
Section 2    : x86/x64 MCA
Descriptor   @ 9201f134
Section      @ 9201f2bc
Offset       : 664
Length       : 272
Flags        : 0x00000000
Severity     : Fatal
Error        : BUSLG_SRC_ERR_*_NOTIMEOUT_ERR (Proc 1 Bank 0)
 Status     : 0xb20000001040080f
AlHill
First, do not be afraid to release the CAPS LOCK.
Second, your processor is not supported on Windows 10.
https://www.intel.com/content/www/us/en/support/articles/000006105/processors.html
Third, your processor is from 2006 - 13 years ago:
https://ark.intel.com/content/www/us/en/ark/products/27516/intel-pentium-d-processor-920-4m-cache-2-80-ghz-800-mhz-fsb.html
Doc
n_scott_pearson
To answer your question, a WHEA Uncorrectable Error does not necessarily mean a problem with the processor. It can (also) occur because of failures on the motherboard or in the memory DIMMs or in a device driver.
As Doc has pointed out, this could be caused by down-rev drivers. You should never upgrade from Windows XP to Windows 10, even if you did come via Windows 7; you should always install from scratch.
PPatt3
Thanks for your reply, I had the same problem under windows 7 Pro BSOD 0x124
I performed a clean install of windows 10 to troubleshoot this problem.
Is there anything else I can do to identify what is causing this problem.?
I've replaced the TIM on processor.
Mainly only happens on security scans or prolonged disk access?
Is the bus error on the processor or in between the processor and disk or memory.
All Disk \ memory \ graphics card \ file scans - sfc /scannow ok?
I installed the original win xp chipset drivers is that ok?
n_scott_pearson
You may also be seeing an overheating issue, either in the CPU or in the PCH (chipset) component. Run AIDA64 or HWiNFO64 or some similar tool that can display the CPU and PCH temperatures and watch what happens as you do these activities. I am not sure if a failure occurring in the PCH's SATA controllers (as a result of overheating or otherwise) can result in a WHEA Uncorrectable Error, but it is a possibility.
