ITBM не работает на моем пк с недавнего времени (после обновления биос)
i9-9980xe, материнская плата - asus x299-e gaming BIOS 3006
никак не могу заставить работать itbm, удалить он себя не дает даже с правами администратора, каждый раз появляется вновь, переустановить не получается - при установке ITBM с официального сайта asus выдает ошибку - install failed
Hello РИфра,
Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool embedded on this Intel Community.
Intel® Turbo Boost Max Technology 3.0 is a combination of software and hardware coupled with information stored in the processor.
You don't need to install any driver, Windows* operating system (OS) has native support for Intel® Turbo Boost Max Technology 3.0 and the feature is enabled automatically. The processor feature Intel® Turbo Boost Max Technology 3.0 is enabled in the hardware and p-code. Make sure you upgrade your Windows OS to the latest version.
Intel® technologies’ features and benefits depend on system configuration and may require enabled hardware, software or service activation
Since the issue started after a BIOS update it's recommended to report this to the system manufacturer since this is native support and the processor loads it automatically.
For more details you can check the following links:
Frequently Asked Questions about Intel® Turbo Boost Max Technology 3.0
Adrian M.
