Processors
14536 Discussions
IccMax values in XTU: how do they affect stability/power/performance?
I can't find any information on the web, or user-friendly explanations at least.
Hello Fabio_V,
Let me double check this matter, in the meantime you can also try posting here: http://forum.hwbot.org/forumdisplay.php?f=130 Intel XTU HWBOT Integration - HWBOT forum for peer to peer assistance.
Amy C.
Ronny_G_Intel
Hello /thread/115613 Fabio_V,
There is very few documentation about it but basically the Intel® Extreme Tuning Utility (Intel® XTU) in general helps out to reduce possible negative incidents when trying to overclock the system. When playing with IccMax stability could be negatively affected, power will increase and performance should be better if done correctly.
I am attaching a picture of what I am looking at, is this the same that you are referring to?
If you need more information, can you provide me with more details about what you are trying to accomplish?
Ronny G
Hi there!
Yes, we're looking at the same parameter. Of course values are different, because my CPU is an i7 6700HQ (on a MSI GE72VR 6RF Apache Pro).
What I want to accomplish is to have at least a couple of profiles: one with lower power consumption for reduced temps and extended battery life, the other one trying to squeeze a little more power from the CPU.
Currently I've been trying to make the first profile, mainly by undervolting. I'm attaching a screenshot for letting you know what I mean, maybe you can point me in better directions.
Thank you!
Ronny_G_Intel
I don't really have any specific recommendation. XTU allows you to set up and test the configuration that works better for you. If you have any specific question please let me know.
Ronny G
