J'aimerais savoir si c'est impossible d'utilisation la virtualisation avec le processeur Intel Celeron T3500 2,10 Ghz.
Si ce n'est pas possible, faut-il changer de processeur ou je peux seulement faire les mises à jour du BIOS?
You have no support for virtualization in this Celeron processor. You would need to upgrade to a Core 2 Duo or Core 2 Quad processor to get Virtualization support. In order to perform this upgrade, you need to check the documentation for your motherboard to see what processors it actually supports. In some case, a BIOS upgrade is necessary to achieve support for particular processors. Again, this is documented in the compatibility information for your motherboard.
Hope this helps,
