Processors
14926 Discussions
Incompatible Driver: igdkmd64.sys Need Solution...
jimmiami
Hello Intel,
I am having an issue with my Dell Computer where this driver igdkmd64.sys is coming up as incompatible and not allowing my core isolation to come on. I need my MS Core Isolation turned back on asap. I have attached my computer CPU below for you to see my home pc.
Please tell me the way to fix this error.
Jean_Intel
Hello jimmiami,
To have a better understanding of your issue, please provide me with the following:
  • What is the driver with issues? Is it related to graphics?
  • Did you install the driver recently? If so, which driver did you install?
  • Do you receive an error message when enabling core isolation?
Based on the screenshot you provided, I noticed that your CPU is an Intel® Core™ i7-6700 Processor. You should know that this processor is not part of the Windows 11 compatibility list. Installing the operating system in a device that isn't supported may impact the well-functioning of your unit.
https://docs.microsoft.com/en-us/windows-hardware/design/minimum/supported/windows-11-supported-intel-processors
Also, you should know that the Core isolation features are part of your Operating system. I would recommend checking this issue with Microsoft for further support and confirming if this issue may be caused by using their operating system in an unsupported problem.
Jean O.
Jean_Intel
Hello jimmiami,
I hope you are doing fine.
Jean O.
Jean_Intel
Hello jimmiami,
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
NigAmos
Same happening on my Dell Optiplex 3020 for these drivers.
03-2023 Windows update failing with core Isolation Memory Integrity off it seem.
NigAmos
Same happening on my Dell Optiplex 3020. 03-2023 Windows update failing with core Isolation Memory Integrity  off it seem.
ictLee
I'm getting a similar message on my home build.  I have an MSI B760 Gaming Plus WIFI Motherboard, 32GB of ddr5 ram, and an Intel core i7-12700KF Processor.  I'm unable to turn on Memory Integrity due to incompatible drivers.  Here's a screenshot of the message.
Thanks for any assistance you can provide.
