Community
cancel
Showing results for
Search instead for
Did you mean:
CMont21
Initial Benchmark causing immediate crash with standard overclock
I have not made any changes, at this point, to my standard overclock on a new system. When I run the initial benchmark in the extreme tuning utility my pc shuts down immediately. No delay, I press the button and it shuts down.
I've run a short (1 min) stress test in the utility, to see if I got an immediate shutdown, but the stress test worked fine.
Motherboard: Asus ROG Strix Z390-E
CPU: Intel Core I9-9900K @3.6GHz
Core Volage: 1.375
Memory: 32GB
Cooler: Corsair H150i Pro
The only change I've made at all since initial setup is to set the bios overclocking to AI Optimized
Tags (1)
AlHill
Update your bios and try again.
Doc
