Processors
13857 Discussions
Intel 10th Gen, 11th Gen i5 TDP vs Power Consumption
kvstst
I read in some articles that the CPU may use more power than the TDP because the TDP is the power consumption when run at base frequency. Is this true?
[Edit:
Why Intel Processors Draw More Power Than Expected: TDP and Turbo Explained (anandtech.com)
Intel's Desktop TDPs No Longer Useful to Predict CPU Power Consumption - ExtremeTech
PBP vs TDP: Intel changes power consumption starting with 12th-gen chips - Liliputing
For example if I am using i5-11500T (Base freq: 1.90GHz, Max turbo: 3.90GHz) with TDP 32W, at Max turbo of 3.90GHz will the power consumption be much higher? Is it possible to have a limit on the max power consumption in the BIOS?
I also noticed that the base frequency for 11th Gen is lower than 10th Gen with the same TDP. For example, i5-11500T has based frequency of 1.50GHz while i5-10500T has base frequency of 2.30GHz. Does it mean the 10th Gen is more efficient?
AlHill
"I read in some articles..."
Provide a source for these articles and claims.
SystormX
Here is an example for you for 12900K:
Before 12th gen, information was only about Base Power, as I remember.
