16765 Discussions
Intel 12th gen Hyper-V support Windows 11
andrgin
I am thinking about buying a new laptop with 12th gen CPU and Windows 11. One main use will be running virtual testmachines using Hyper-V.
I heard about compatibility problems with Hyper-V if efficiency cores are enabled (system will not boot, virtual machines fail to start etc.).
Has this already been solved with Windows 11 or has Intel any suggested workarounds if the BIOS does not have an optional to disable efficiency cores?
DeividA_Intel
Hello andrgin,
Thank you for posting on the Intel® communities. I understand that you have questions about the Hyper-V technology.
1. Can you share a link to the article or website where you read about the issue with the Hyper-V technology?
2. Can you provide the exact brand and model name of the processor of the laptop that you want to buy?
3. Can you provide more details about how you are going to use the Hyper-V technology?
Deivid A.
andrgin
Hallo Deivid
Thanks for your reply.
1.) Here are few reports from other users:
https://www.reddit.com/r/HyperV/comments/skbfk0/microsoft_windows_server_2022_hyperv_role_and/
https://www.reddit.com/r/HyperV/comments/s8hgr1/hyperv_on_intel_12900k/
https://techcommunity.microsoft.com/t5/windows-server-for-it-pro/alder-lake-12th-gen-intel-cpu-won-t-boot-on-windows-server-2022/m-p/3010622
https://www.overclockers.com/forums/threads/hyper-v-and-alder-lake-s-issues.801194/
2.) I have 2 options:
I am interested in a Core i7 1260P: https://ark.intel.com/content/www/us/en/ark/products/226254/intel-core-i71260p-processor-18m-cache-up-to-4-70-ghz.html
Model of the laptop will be a Dell Vostro 5620
3.) I want to use Windows 11 as my host OS. Guest operating systems will be:
.) Windows 10 64 Bit
.) Windows 10 32 Bit
.) Windows 7 32 Bit
.) Windows XP 32 Bit
.) Windows Server 2022
.) Beta releases of upcoming Windows operating systems
DeividA_Intel
Hello andrgin,
Thank you for the information provided
Deivid A.
DeividA_Intel
Hello andrgin,
Thanks for your patience. Based on the investigation, we have not seen any issue reports with virtualization or Hyper-V on our side. I would like to inform you that virtualization is available for the Intel® Core™ i7-1260P Processor.
However, I recommend checking with Microsoft to confirm if the Hyper-V feature is compatible with your processor and your laptop/motherboard since HyperV is a feature of the operating system.
Deivid A.
