Try to tackle the INTEL-SA-00075 issue (CVE-2017-5689). Currently using HP Z440. Already apply patch SP80050 according the the site and see the firmware are up from 9.1.37.1002 to 9.1.41.3024. However, still go the error message like this:
Risk Assessment
Based on the analysis performed by this tool, this system's Firmware has been updated and system is in unprovisioned state. See Explanation for specifics.
Explanation:
The detected firmware on this system has the fix for INTEL-SA-00075. Ensure that the INTEL-SA-00075 tools were used to perform a full unprovisioning of the system prior to reprovisioning. This will remove any unauthorized configuration settings.
How do it reprovisioning again?
Also, what exactly is "Intel Active Management Technology, Intel Small Business Technology, and Intel Standard Manageability"? I might just as well disable it at all.
Any help is appreciate.
Hello fungroy,
Thank you for joining the community
We will proceed to close this thread as per there is a case already opened with Intel where this issue is been addressed. We encourage you to continue working on the original ticket.
Jose A.
